Discuss Grundfos UPS 3 pump - blocked message in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have moved into a house which uses a Grundfos UPS 3 pump to circulate the water in a wet underfloor heating system. Last autumn the pump would not start - the blocked message showed - so I replaced it. This year, the same thing has happened with the new pump. I have freed the impeller using a screwdriver as advised in the instructions but the red and orange error signal still appears. Any suggestions ?
Screwdriver in the centre and give it a wack inwards
It’s a common problem they don’t like not working for months best to turn it on and run it once a month
Reply to Grundfos UPS 3 pump - blocked message in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
