N
Nat
Hi all,
Some advice/help please.
Fitted a thermostatic shower suitable for low pressure on what I thought was a balanced gravity fed system, teed into bath supply.
Turns out the cold supply is actually mains and so the shower is working properly when turned over to hot it just trickles out. There is enough head because when I use the shower mixer from the bath taps and hold it up to shower height the flow is OK.
The manufacturer says that the shower can handle of pressure differential of twice as which pressure on one side to the other. I reckon there's maybe 0.4 on the hot side and probably 2-3 on the cold. So there are a couple of options: reduce the cold pressure or put up the hot.
Has anyone tried putting a PRV onto the cold in a situation like this? I have found one that can reduce to 0.5 bar (£70!) and it would be a really easy job to cut it into the cold supply to the shower. Would this work?
Or I could fit a single impeller pump to the hot. Which brings me to another question: can I just cut the pump into the hot off the cylinder so I am in fact pumping all the hot draw offs to save running a separate supply to the shower and taking the floor up etc? Or is this going to draw in air from the open vent? Am I going to need to fit a flange?
Cheers
Nat
Cheers
Nat
