Discuss Ufh, with microbore rads in the Water Underfloor Heating Advice area at PlumbersForums.net
gingalig
Apologies if its already been covered. I've been asked to quote on a heat only with a solar compatible unvented, the existing system is 10mm microbore gravity fed to rads. I'm confident of the conversion and have my gas safe and G3, I've also been been asked to provide an outlet for, and install ufh. My concern is that the Ufh will act as a bypass. What preventative would I need. Excuse the ignorance but I don't usually work on Underfloor. Thank you.
Two port valve and cct (close coupled tees) after the zone valve
There the same just some separation
Ufh sometimes only need a few kw this is where cct help with cycling etc
@ShaunCorbs. Sorry for my ignorance this time. What is the close coupled tees actually doing? Installations is not my thing obviously lol.
In short it’s allowing the boiler circuit to flow independently of the ufh circuit
So when the ufh starts to get upto temp the mixing valve starts to close and pick up from the return so the flow is a trickle
With the cct before it still let’s the boiler circulate
Thanks Shaun. From what you said and what I've read I have a basic understanding of hydraulic separation but I'm not an installer and have not even seen this set up in person. All our work was just oil burners.
Reply to Ufh, with microbore rads in the Water Underfloor Heating Advice area at PlumbersForums.net
Hi, I have an 20yrs heat only potterton 50e boiler with 196x old house - suspended floor - designer radiators, open vent system and hot water...
Hi All I'm planning on replacing a couple of rads soon as they are far too small for the size of the room causing the room to take an age to heat...
I am told I need to replace my boiler. I am considering a system boiler so I can lose the tank in the loft and feed it direct from the mains...
Bit of advice needed. Searched but couldn't find anything about Combi's and UFH with no rads. Customer wants to have a combi, UFH but no...
Hi folks, I’m in need of some sound advice. We have recently had a ground floor extension and have had underfloor heating (company: JK UFH)...
4K
