Discuss UFH From Buffer Tank - Is 'Boiler Enable' call for heat required? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, hopefully a simple question, but wanted to ask those who've a bit more experience than myself.
Obviously an UFH system would normally (in a typical gas/combi boiler scenario) send a call for heat from the boiler, firing the boiler into life.
I have a Biomass (wood pellet) boiler (with buffer tank) and I've installed an UFH system which draws water from a buffer tank through the UFH pump - so is a 'boiler enable' feed from the UFH system (to the boiler) actually required?
My thought being the heat is already present in the buffer tank, so when a thermostat switches the UFH system (i.e. the pump) on, surely sending a call for heat to the boiler is unnecessary? of course if the UFH draw causes the buffer tank temperature to drop, then this would be detected and create a call for heat from the boiler through the boiler's own system - separate to the UFH entirely?
Hopefully the above makes sense - I just wanted a sanity check that I was doing the right thing - Any questions/additional info required - please let me know.
(apologies if this should fall into the 'renewables' section - I assumed the principles would apply to a buffer tank regardless of heat source)
Many thanks in advance!
Much what I intend to do later this year. To me it makes sense to control the boiler firing by sensing the temperature of the buffer tank rather than having the UFH call the boiler for heat. We are thinking alike (but remember that fools seldom differ).
Reply to UFH From Buffer Tank - Is 'Boiler Enable' call for heat required? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented...
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem...
Hello I'm new to the forum and wanted to ask a question after having a good read. House is undergoing a complete renovation and new pipework needs...
I have a thermal store heated by a boiler with its own thermostat. I also have a stove with a back boiler. The stove heats water in a separate...
Hello all, I should start off by stating that I'm not in the industry - I'm just a DIYer with a "what-if" idea. Hybrid systems and solar...
