Discuss UFH 5 port blend valve leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
Jonathan Cope
Hi all,
hoping someone can help. Valve is leaking from the pin and i've looked everywhere for a part. Anyone recognise the attached and where I can get one please? Main thread is approx 200mm Dia.
Port is big brass block with 5 ports, can't find that anywhere either!
Cheers,
JC
Probably just a leaking o ring on the shaft seal if you can dismantle & buy an o ring set?
Buy an o ring set like said before lol... Need a bit of luck normally tho, there either too big or too small ;)
Reply to UFH 5 port blend valve leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
