Discuss Toilet troubles - not flushing in the USA area at PlumbersForums.net
Hi all,
I have zero clue about plumbing. Recently my push button flush has been reluctant to flush first time round, and now refuses to at all!
For background the tank is full of water.
Is it hard to fix for a person who knows nothing about the world of plumbing? Is there a way to "manually" flush the toilet in the meantime?
Thanks in advance!!
Hi all,
Thanks in advance!!
Depending on the type of flush siphon you have it can be very simple or a real pain. Post a piccy with the cistern lid off and any details of make model etc. Centralheatking
Until we know what setup you have, the simplest manual flush you'll get is half a bucket of water chucked into the pan to clear it until we can help you get it fixed.
I've added a couple of pics. No make or model unfortunately!
Looks like a pneumatically operated flush valve. Could be the clear plastic tube that's split or the actual push button that's given up the ghost.
If the pneumatic hose is just pushed onto the back of the button, simply pushed onto a little spigot, you can at least eliminate the bellows inside the button from being at fault by pulling the hose off and blowing sharply down it. I don't mean just blow on it like you are doing a dandelion, actually seal your chops around the end of the tube and give it a good blow.
If the flush valve lifts and flushes the toilet, it's probably the button at fault. If it does not flush the problem is in the flush valve inside the cistern or the hose is split somewhere.
Give it a test! (and report back with your findings)
Its a Grohe flush valve, there are two possible faults here, 1 is the small bellows you can just see in the top of the cistern near the plastic piece. You can disconnect the plastic tube from the button and blow down it if it flushes its the button if not its the small plastic bellows under the white plastic frame. This will unclip to take out. be aware of its position when you take it out. Good luck
Reply to Toilet troubles - not flushing in the USA area at PlumbersForums.net
Hi, I have been having water hammer after flushing toilet in the past couple of weeks. I have tried turning off the stopcock and opened all taps...
2K
J
Hi, I,'m after some advice please. We have recently had a new bathroom fitted by a professional fitter. We chose the units and he purchased and...
3K
Hi all, just a side note to start, I am not a plumber and have pretty much zero knowledge about plumbing. I have three toilets in my house, a...
Deleted member 120897
We are trying to replace the push button flush on our toilet. We've got a replacement flush, that includes seals for 1.5" and 2" cisterns, however...
Hi All, I really need some advice on a home plumbing issue please. We have a sound when closing taps and flushing toilets that started a few...
