Discuss Today's install. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
noose.jpg...
Lovely install! Is that an open end left on a gas pipe?!....
And I'd guess at a Worcester ri boiler!
It is but a future gas pipe, open both ends, the clients using the original boiler which is being moved from one end of the house to the other, so all the pipes are in place for the changeover.
And all wrong on the boler guesses. :)
Was just going to put vent on top of boiler, do megaflow specify otherwise?
flue easily clears gutter/ soffit. The drawing is a rough outline.
We'll see for sure tomorrow, it's changeover day.
yep should have one on coil flow pal, all covered in MI's
I reckon its a Chaffoteaux Challenger that he has been saving for that "special" job.
On second thoughts, he's taken an old Diplomat out of a demolition job, and now he's going to wall hang the beast, and get another 40 years out of it. :)
Apart from the wall-hanging part, thats probably not as silly as it sounds. :)
Ps nice work but York bottom clip on the horizontal run is on the pull bend and at an angle -1 point
Nice job ,, Can't see the balance valve on the cylinder return , !!!
Under Part L balance valves shouldn't be fitted to the hot water primaries. The balancing valve is to ensure that there is capacity to run the heating and hot water at the same time. Modern control systems allow the water heating to be timed earlier than the heating which enables a quicker more efficient heat up time with no detrimental effect on the heating.
i reckon it's an Apollo Fanfare being fitted.
"it is reccommended that an air bleed point or automatic air vent is incorporated in the primary return pipework close to the megaflow eco unit"
surley my vent near the boiler should suffice? What would everyone else do?
Vent on flow and return next to unvented cylinder and vent on flow to vented cylinder !
Vent I use is manual not automatic on sealed systems !
vent on open vent I use are automatic
what i would do is loose no sleep what so ever over an air vent
And the winner of 4 kazillion points is...... Gasmanrob.
Clapclapclapclapclap.
And before you Lot start going on this was before the condensate was finished.
Pahah that's why the apprentice nearly cut his finger off today!
Reply to Today's install. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
After some advice please. Recently bought some shower panels to have installed. However the installers must have missed installing the waterproof...
How it best to install pipework to best avoid airlocks with gravity hot water. Install level or slightly down hill in direction of flow? Thanks
Hi All, The temperature knob on my Hansgrohe Ecostat S shower mixer has been installed insecurely and is loose when pulled, I've looked at the...
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
  • Locked
Hi, I recently fitted a new central heating circuit and ran hot and cold to the bathroom and kitchen in my property (I was a CORGI registered...
