Discuss Tile backer board recommendations in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
They will do the job budHi. I didn't really want a heavy Hardie Backer. I did find these STS backer boards from Wickes. (I need a board that I can pick up from a shop) They appear to be lightweight and they are not being used with porous tiles/grout, but instead wall panels.
5hanks for your input by the way
Thanks KOP.They will do the job bud
They will, but they're the same weight as hardibacker ~ 14kg per 12mm sheet.They will do the job bud
You might be confusing the backer boards with construction board.They will, but they're the same weight as hardibacker ~ 14kg per 12mm sheet.
Reply to Tile backer board recommendations in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
