Discuss Tiger Loop Full Up? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
stoneruk
Hi all, went to turn my OFCH on and it didn't fire up. Had a look in boiler house and noticed the Tiger Loop was filled right to the top. I can remember looking at it before and there was only a small amount of oil in the bottom, but now it is filled to the top.
With another look at it, it seems as if there's water in it?
Any ideas?
EDIT:: Just been informed by the mrs that the cover for the oil tank had been left open when it was raining! Where do i go from here?
Thanks.
to the bank my friend.
dont know it all will advise how much to withdraw
You could get the water removed from oil tank, but water & maybe some corrosion will be in oil pipe , filter, fittings, oil hoses, tiger loop, oil pump, nozzle & rest of burner. Salvage what you can, sometimes you can get away with not much damage. Tigerloop will be a curse to do much with. Should mention that water & corroded iron etc, inside copper oil lines can rot the copper! So worth changing oil lines if in doubt.
dontknowitall will put you in the right direction or one of the other oil guys, while you nip to the bank.lol.
good idea to post whereabouts you are though in the meantime.
Does anyone have any idea why the Tigerloop would be filled to the top? Like i said before i've noticed it when running smoothly and there was only a little bit of oil in the bottom of it.
Reply to Tiger Loop Full Up? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Hi all, all new to this breakdown life, currently waiting on getting on a training course, so just been relying on technical and instructions...
CJAY40
C
Hi, Over the past few months, my wife and I have noticed a constant pulsing sound throughout the house which is particularly noisy at night (this...
Hi, Looking to see if anyone can give some advice please. My Baxi boiler has been losing pressure and I am having to top it up approx. every 4...
Hi all. As the title says, I have a problem with an unvented cylinder I had installed last year where the first time I turn a hot tap on after the...
2K
Client ran out of oil. Locked out. Has Grant eco ext. wall boiler 1.3 mtrs off ground. Tiger loop on wall same height as burner. Tank 4mtrs away...
9K
