Discuss Thorn Apollo.......but which one? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
gassius clay
Hi guys I came across a thorn apollo today and it needs some parts but has no GC number or anything to identify it.All I can say is it is probably as old as me.How on earth do I find out what model it is. Any help would be appreciated.Thanks
you will be lucky to get any parts for that mate
Did you look in bottom cover ? sometimes its inside combustion chamber or on side , look under Myson they took over Thorne. What parts you after ?
I thought Thorn were part of the Baxi group now?
There should be some parts lists and a manual on Parts Arena.
Isn't the databadge on the combustion chamber door on these? Seem to remember it being riveted on??
i can get a new data badge for it. but which one is it lol.
here is a part no 402C2226
still get gas valves / thermocouples and may be the pilot assy dont think you will get much else
I'm fitting a pump overrun to one next week. They came in 3 sizes far as I remember 15/30, 30/50 & 65/80. The o/heat stat was the part that varied the most unless it's something specific to the 'boiler size' you're after?
The data badge was a sticker, that has crumbled away due to the heat from the combustion cover. Seen it loads of times.
This is where I get confused, the OP is not GSR so how come we are talking about looking in/around combustion chamber etc etc?
Thorn Apollo. I have one still running at my home. What parts you looking for as they don't have too much parts inside.
Reply to Thorn Apollo.......but which one? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Am trying to understand my mother's Apollo boiler. It has an intermittent fault. In the last couple of years, it has had a new...
Hi, I live in a really remote part of the Highlands, so paying for a plumber (or electrician?) to do this will be brutally expensive, so I need to...
Hey folks, I'm wondering if someone could possibly help, I'm looking for a possible part number b4 I call ideal in the morning, I fitted an...
Deleted member 120897
I need some advice on whether to have the early model burner, 87181206190 replaced with the same part number Mk 5 type. I have my annual service...
I have read a few threads including one by Debbie Stano that were similar to my issue but that thread stopped a while back without any resolution...
