Discuss the perfect boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
ambrosia
driving along day dreaming and bored (worst thing about my job, all the driving)
and i'm trying to put together the perfect boiler, so far I'm thinking;
ntc from vaillant, they never go wrong,
fan from remeha never changed one of them so they must be good
pcb from worcester, i know i pig about worcesters but their pcbs are good
plate heat, vokera, curve ball but i like the way theyre insulated
flue, keston, has to be and i'm not expecting anyone to disagree on this one
gas valve, baxi
so now i'm stuck on diverter valve, pump and the all important heat exchanger, i was thinking vissemann but not sure
oh and case, i was thinking ideal as they are a quiet boiler, but dont have access from the sides
gas valve baxi ??? Changed loads of them they even sued the company who manufactured them .
Worcester pcb go faulty daily as well
older ones yes, newer greenstar etc seem good to me
gas valve i was struggling with, but ecoblue and platinum i havent changed many whereas vaillant worcesters i've done loads
Perfect boiler ...... Viessmann , the end !! Lol
nooooooo, terrible customer service, flow and return rubber hose, same have to take everything out as worcester type system, overly complicated controls, some have no pressure gauge and theyre too expensive
Heat exchanger intergas, then don't need diverter
not comfortable with those twin pass heat exchanger, also not enough market share so parts in the future could become hard to get
ambrosia;866321not comfortable with those twin pass heat exchanger said:
Oh thee of little faith, just think no more cut pinkies replacing WB plate hexes
Perfect boiler for me would be one that costsÂŁÂŁÂŁÂŁ to supply, and breaks down every three months so I can repair it lol
has to be a grundfos pump,none of this a rated tripe though,good old 15/60 selectric,as for a heat exchanger,i am not going to say giacomini ,veissman for the larger waterways,diverter either the baxi 105,cheap to fix or a giacomini type fitted in the earlier duotec HE with ptfe o rings
Terrible customer service lol, you need to meet my regional guy , second to non . I am with you on the hoses though , orrible things . Complicated controls Pfftttt they cant be , I can set them up lol.
I quite like the diverters on the Greenstars, easy to fix, complete kit with motor is cheapish and most times you can clean the rubber seal off and it's fine.
Isn't it one screw and one electrical plug? Better than an Alpha..... Lost 3 hours of my life to one Friday....
Atag have created such a range of boilers, the only thing i can complain about is.... there is nothing to complain about.
not recent tho so they must be leaving them too it (round 2014-2015 i think )
Atag have created something very special, book a visit from the rep its worth it.
I boiler switches off after a year and has to have a service reset by registered engineer.
Plus also make a good cup of tea.
Reply to the perfect boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
