Discuss The dreaded tiled floor problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
townfanjon
Subscribed
..... I have never done this but cant see why it wont work .
Customer has a one pipe system and wants a small towel rad in a downstairs toilet, but I cant get under the floor to plumb the towel rad into the one pipe , but can get to the pipe by lifting another rooms floor , and sliding some micro bore under the tiled floor .
In other words I am taking Two tees off the same pipe and feeding the proposed towel rail , not ideal I know , anybody see any problems ???
Many thanks
Aslong as there swept / diverter tees then your fine
How long will the runs be from the tees? Also are the other rads in microbore? I haven't seen a one pipe system with microbore on it before.
I was nearly going to say it won't work, but as Shaun said, with swept tees it hopefully will.
Without swept tees the flow won't go through the rad.
No pal , no others , I am just going to tee off the one pipe around 2 meters or less to a one off little towel rail, and then tee it back into the same pipe . Not good I know.
Yep swept tees will defo force the flow , good call from Shaun , but even without the swept tees I still think it could get warm through heat transfer . Poople who tile timber floors without access to pipes and wires should be made to watch a full season watching Bradford City , and then be shot .
Definitely people who get their floors all tiled or hardwood on top and then ask for a radiator to be installed on a different wall, - should be brain scanned!
How different things used to be in the good old days when people mainly used carpets. :)
I don't think you would get heat transfer with one pipe connected with microbore using ordinary tees. Unless your rad was almost on top of the main run.
That's what I was thinking, - microbore airlocks very easily and likely to be all sorts of rises and falls in the pipes when you push it blindly below a floor
With swept tees you should be fine tbh
Reply to The dreaded tiled floor problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
