Currently reading:
Tesco Direct - Premium 30 Metre Hose Pipe With Accessories - £5.50
Discuss Tesco Direct - Premium 30 Metre Hose Pipe With Accessories - £5.50 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
These cheap hoses normally have 500 kinks in them after a week in the van! The drain off ****es out then lol!
I have a hoselock anti kink, had it a couple years now... Roll it carefully after each use & not a single kink yet :)
Regin drainsown kit £40 ish! Best by far
Is this for 30 metre? As they sell a 10 metre orange hose for that money.
seems a lot for a hose pipe.
It's about 10m the RRP £69?
Once you have had rubber you can't go back! Just don't put 1.5 bar on it as it balloons then pops. But it's a drain down hose and that's what it's good for. One end has a bit of 15mm with a 3/4 rad tail sweated on it, can connect to any rad and helps hose sink to bottom of cylinder when syphoning !
Like the rad tail idea when syphoning, I'm having that thanks!
dont you have both types of rad tail though, 3/4 type and 15mm compression?
i have made up temporary drain offs, rad tail, 1/2 brass socket and 1/2 threaded drain off.
back to hoses, I bought a yellow hose from Screwfix about 13 years ago and cut it into 3 as it was so long, all 3 hoses still are fine.
Reply to Tesco Direct - Premium 30 Metre Hose Pipe With Accessories - £5.50 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
