Discuss Tap cartridge identification? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi - I've got a quarter-turn cartridge that I'm trying to identify please - 35mm x 58mm. It's about 25 years old and uses square profile o rings.... can't find anything online that matches and unfortunately don't have original manufacturer's details.
Many thanks.
Probably doesn’t matter, usually the orings have to fit in the cartridge but the brass surface of the tap seat is usually flat so the o ring profile won’t matter. ( often has two indents for locating lugs on the cartridge, to index it so the orings sit over the holes correctly as there is not much coverage)
Reply to Tap cartridge identification? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
