Discuss Sudden Pressure drop in the whole system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
Humpty
Good afternoon,
I noticed this a week or so ago but have kept putting it off thinking 'I'll ask later' but it's getting frustrating so let me describe the problem:
One evening I go for a shower and turn it on when I suddenly realise that the shower is only working at half pressure... I thought someone turned the tap on in the kitchen or something. The next day I made sure no one is using the water and turned on the tap... half pressure in the whole flat! when two taps are on or the toilet is refilling then water slows to a trickle. I have checked the meter outside in case there was a leak in the pipes somewhere but no, no leak. So why the drop in pressure? I'm not a plumber but I am technically minded.. ish... can someone give me some hints? Is calling a plumber unavoidable?
Thanks in advance guys!
first thing i would do is ask neighbours if they are experiencing same, it could be a leak external to your property boundary which is causing the drop. in which case call your water undertaker.
if neighbours are ok then it will be a localised problem but could still be caused by debris entering the system as a result of water companies works etc.
you did check the obvious....stop tap not been turned down by anyone??
Thanks for the reply! Should have said that I asked neighbours immediately and they said all was fine, no one in my flat touched the valves and the one outside was checked by me and it's on 100%. There is a valve in the bathroom but I cannot move it in any direction...
any mains work been done recently ?? have you got a pressure reducing valve fitted on your mains ?? or any filters which may have become blocked with debris ??
There was no work done to the property or the mains to my knowledge... I think the neighbours did some work upstairs but may not even be plumbing. About the filters... where would they be located?
at the meter or any pressure reducing valves you may have in your pipes, any type of valve which would have a filter inside it
Hmm... Looks like I am going to have to call the plumber on this one...
im only speculating mate but i would try the water board first before you call a plumber
Are there any tanks in your flat? What kind of boiler do you have?
I think we have a tiny one under the combi boiler... It's the cold water pressure that is low btw, as a consequence so is the hot
Right so you have a combi, its just I've seen some flats plumbed so badly that all cold water (including kitchen tap) is from dirty old lid less tanks in the loft.
Any gassafe guys know what that small tank under the boiler is??
Reply to Sudden Pressure drop in the whole system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem...
M
Hi, we have a back combi heater. Whenever the heating comes on it seems to lose pressure within a few hours and I have to refill each morning...
G
Recently we had reason to replace our boiler. It was on the blink and you could only con it into coming on by first turning on the hot water and...
Hey Guys I’ve noticed this weekend that my en-suite toilet pan water level is seeming to regress after an hour. Toilet flushes as normal and...
