Discuss Strapping pipe clips in the Plumbing Jobs | The Job-board area at PlumbersForums.net
F
flappy8
Hi all,
I've seen some metal strapping which is sometimes used to hold soil/other pipes in position in voids etc. Its flexible and almost looks like bike chain but allows you to make your own constructions/custom brackets. Anyone know what it's really called or where to get it? Done some googling but no luck!
Do you mean all-round band?
Brilliant stuff, like gripfill, duct-tape and LS-X. You know its a bodge, but you always have it on the van! :)
Ray, as a director I find it amazing that you know so much about the nuts and bolts plus technical side of the trade.
I take my hat off to you Sir.
I would have thought that a deep understanding of all-round band, gripfill, duct-tape and LS-X put me firmly in the "cowboy" camp! But thanks for the kind words anyway. :)
In my western book you're John Wayne.
Oh, and P.S.
Ermi's: Clint Eastwood
Croppie's: Eli wallach:)
I can feel a slap coming my way.
Do you mean all round band
That's exactly what I was thinking of - just couldn't find the right name - seems obvious now!
+1 for using correct clips where you can - however as everyone knows that's not always possible!
A better product might be M10 rubber lined brackets with M10 rod cut to the desired length and fixed to the wall with a backplate.
Pipe brackets where possible bit likes of underneath floors ., joists i always use clipstrap banding but surface pipes always brackets..dont think ive ever used the old duck tape yet. But never say never...
Good old builders banding is great for lots of situations. Not for flues tho and not really for soil pipes
AW why not waste pipes ?
The clipstrap i carry in the van certainly wouldnt snap as you struggle to cut with snips sometimes ,
Euro-clips, studding cut to length, nuts 'n feet are good. Lots of other ways to susped from rsj's, steel framed buildings etc. but sometimes there is a need for strapping.
it could be used if done correctly, remembering that plastic waste needs to expand alittle. what i tend to see is a 110mm pipe wedged against a wall banded back which is really poor and lazy, using the correct clips is much better ensuring correct spacing and loadings on the fittings.
i use it often myself, normaly i put some lagging between it and any pipework, its great for lagged pipework resting on roof timbers or under ground floor joists etc...
Reply to Strapping pipe clips in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Hey, I'll start by saying I'll be getting a plumber out to do this but wanted some advice first. We're redoing our ground floor bathroom this year...
Hi, Short version: I have about 4" of pipe sticking out of a concrete floor in a cupboard. It makes a 45-degree bend as it exists (bent, not with...
1K
Hi Folks, I have a challenge with a Main Eco Elite 30 Combi which is short cycling on the CH. Water works fine. As soon as you have call for...
Hi! Our main stopcock is weeping. I phoned the water company, first-person thought it was their problem as it was on the 'outside' of the water...
Hello, I would very much appreciate some help/feedback on what I am proposing for my very small ensuite bathroom. While refurbishing it I’m...
4K
