Discuss Solid fuel back boiler and pipe stats in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
mrlennie
Hey a question about solid fuel boilers and pipe stats.
If you had a house with central heating and the house only got luke warm the pump seemed to be running (vibrating when touched) checked pipes coming from boiler they were hot could hold them for say 2 seconds so not steaming.
The only thing it could be would be the pipe stat is goosed and doesnt call for heat?
Also are there any good websites for s plan and y plan diagrams?:cool:
Thanks guys
Reply to Solid fuel back boiler and pipe stats in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Firstly I won't be touching or going anything... I only want advice if this is right.. my partners dad has a aga that is solid fuel unregulated...
A bit of an unusual topic, as these are very rare in the UK. I went back to Poland to commission, test and tune the 20kW solid fuel boiler and...
Hi My grandmothers property has a back boiler heated by a solid fuel appliance using coal. Yes, I know. She’s stubborn! Unfortunately the...
2K
Hi Have a 4 port solid fuel back boiler, is the any disadvantages of capping two of the ports off, (eg top left bottom right) then using it as a...
