Discuss Solar Thermal Cylinder Installation in the Renewables area at PlumbersForums.net
Thanks, could you clarify which bit you are referring to - so that I know exactly what I will be referring to when go back to them (and perhaps Gas Safe to make sure they were G3 qualified). Thanks for your input.
We can tick this one off. The cylinder is connected to the gas boiler for heating and water. Its also connected to the solar panel. Cheers.If it’s not connected to a gas boiler then gas safe won’t be interested.
When you refer to D1 and D2 - what does that mean? I think you are referring to the pipes from the valve but is the "D" for down? Thanks.D1 is rising
T and p has been altered from manufacturers spec
No tundish
D1 is too long
D2 is incorrectly sized
2 port is inaccessible
Pump is inaccessible
just to name a few
Reply to Solar Thermal Cylinder Installation in the Renewables area at PlumbersForums.net
