Discuss Soil Pipe Connection in the DIY Plumbing Forum area at PlumbersForums.net
What size coupler do I need to connect soil pipe to main drain - please see photos
Ooo that looks like nice easy digging, wish the ground was like that around here.
If youā€™re undertaking such work you will definitely have use for a tape measure, now would be a good time to buy one.
Reply to Soil Pipe Connection in the DIY Plumbing Forum area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
