Discuss Smelly hot water - unvented in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
Bunker
The foreman at one of my estates tells me a tenant is complaining of smelly hot water. He says the previous tenant had the cylinder and boiler stats up too high so the water would steam, he has changed this. Our man took out the heater and shovelled out the limescale in case it was that smelling but still it continues apparently. While doing this, the tank remained dry so no apparent contamination from the primaries.
Before I get involved, anyone had this before?
There is no HW circ pump.
Similar to a car fart on big acceleration,
have you checked the filling loop i had one on a combi with the guts drilled out andleft open
I know of an instance where a cat climbed in to an unvented cylinder during manufacture and was trapped in it when immersion was put in subsequently died. Whole cylinder was installed in the uk (not country of manufacture) customers complained hot taps were blocking up all the time and the water looked and smelt strange.
Cooked cat anyone.
think about that when you brush your teeth at your mixer tap.
Could be the expansion vessel faulty or a ch type used on potable water, I've had a couple like this.
Cooked cat anyone.
that was just the local chineese soaking before cooking it up
Reply to Smelly hot water - unvented in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hello we have an unvented system. we have an issue where the hot water is hot for 10 seconds and then luke warm, turn off taps / wait and turn...
Hi, We have a large Heatrea Sadia unvented hot water tank, not sure of the size in liters but its about 1600mm tall. The tank is around 3 years...
Hi all. As the title says, I have a problem with an unvented cylinder I had installed last year where the first time I turn a hot tap on after the...
2K
Hi, I’m having a problem with hw venting into the small header tank. This happens when it’s set to hw only or CH. I’ve tried lowering the water...
2K
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
