Discuss Single flow kitchen sink mixer tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
If fitting a kitchen sink tap(single flow) were the water mixes in the tap body. If mains cold and gravity fed hot water. Do I need to put single check valves on both the hot and cold supply's to the sink?
just the hot supply, but i would be surprised if you got much hot out of the tap on blend (hot and cold)
best would be change the tape for a separate type (doesnt mix in the body)
Thank you yes IL see about changing the tap. Can imagine the check valve will make the hot water flow poor. Does the cold definitely not need a check valve then?
that would be the best solution
and yes it would reduce it by about 1/4
and no as the hot wouldn't flow up the cold as its more pressure
And with a dual flow one check valves aren't needed, as the water doesn't mix in the tap?
Thats is resulting in better flow from the hot but be careful you don't get one that mixes in the spout
What happens if mains water supply is cut off? Wouldn't the hot water flow back into it and contaminate?
Only if the tap is opened can't see why you open the cold side when it was shut off abd run hot water
Reply to Single flow kitchen sink mixer tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
