Discuss Sideways Concealed Cistern Advice!? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
david87654321
Hi, Hoping you may be able to advice me...
I'm trying to fit a toilet between a wall and a door - a 2ft gap. Sadly I also need to fit in a 1ft pipe to one side behind the toilet - and can't afford to move the toilet forward. I therefore need my 400mm approx pan to overlap the front of this additional large pipe, in order to clear the door, and find a way of squeezing in a concealed cistern on the other side.
I am therefore trying to find a cistern that is no more than 1ft (300mm) wide, which I would then mount SIDEWAYS (so the width becomes the depth) allowing the flush pipe to keep as close as possible to the middle of my 2ft gap, and further allowing a 400mm wide toilet pan still to be floor mounted. Does that make sense?
Can anyone foresee any pitfalls with this idea (such as fixing a flush button/handle), or have a better recommendation, such as an off-set cistern (although I have been warned this may cause the water to flush with little impact)...
Thanks for any help or advice you may have...
David :)
Hi david
you probably would have more success with a plastic waste paper bin
Have you considered one of those powered flushers. Never fitted one myself but I've seen them in a hotel. Perhaps someone else here has.
powered flushers or "fluxors" are just a mains fed pipe direct to pan, ok in europe, but you'd have to work your way around our building regs to fit one here!
Thanks everyone... anyone know where I might be able to find the narrowest concealed cistern?
Another idea altogether -
Have you room for a high level cistern above head height?
stick the cistern in the loft then bring down via the boxing a 11/2'' pipe to a low level cistern pan using 2- 90 deg bends, flushed as whpes says, via a long chain h.l.c through cieling idea.
Thank you everyone... yes, loft idea is a gooden, there is a bedroom in the loft above, but I may be able to offset the cistern a little to get it into the eaves storage (and then buy a quiet flushing one!). The cistern won't fit higher within the bathroom itself sadly - as the other pipe runs all the way up through the roof (it's the flue for the fire in the lounge below).
You could fit a silent fill valve to your cistern if it is a high level one.
If you can I would test the high level idea prior to actually installing it,
the added force may cause the flush to be more powerfull than the pan can handle and
result in water and turds hitting the ceiling.
You can get round this by fitting a few right angle bends in the flush pipe to slow it down.
Reply to Sideways Concealed Cistern Advice!? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all Relatively inexperienced homeowner here. Apologies in advance if I get any terminology wrong. Today I noticed some limescale accumulation...
1K
C
  • Locked
Hi Please forgive if this question is too simple After flushing the loo takes ages to refill water. It says online I should change the filled...
3K
cidfenmaria
C
  • Locked
Hi all - I have just fitted a new pan to an old concealed cistern - the cistern is behind tiled plasterboard. I have 'refurbished' the cistern by...
7K
DIY-Dave
K
  • Locked
hi guys, after a bit of advice here. just installed a vanity unit, from plumbworld - came with a concealed cistern. The pipe from the cistern...
14K
k13wjd
K
L
  • Locked
Hi! I've come to fit my new Conceala 2 concealed cistern today - pan on flush bend sorted - I went back to find the instructions to read about...
3K
LukeTheGooner
L
