Discuss Problem with concealed cistern flushing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
DIY-Dave
Hi all - I have just fitted a new pan to an old concealed cistern - the cistern is behind tiled plasterboard. I have 'refurbished' the cistern by replacing the syphon and ball valve. However the flush is now not powerful to flush properly and keeps going for a long time.
Is this because the syphon is not compatible with the new pan and I need to replace the syphon with a flush valve? If so is the type of flush valve and the size of the cistern important? (It's an old cistern capacity greater than 6 Litres).
Any help would be greatly appreciated - thank you.
I would suggest that there is a problem with the new gear in the cistern. Is the float allowing enough water level in the cidtern. Did you adjust it ??
Thanks for your quick reply - yes the water level is more or less as high as it can go. Could it be the size of the syphon that is the problem?
check your syphon with the old one [assuming you still have it] it needs to be the same as it was the one designed for this cistern. while they may all look the same some are higher off the base of the cistern some also have plugs to allow for different amounts of water i.e 6/7.5/9ltr to flush so proberbly easier to over haul old syphon hope this helps:) regards turnpin
Thanks Turnpin. Unfortunately I don't have the old syphon any more so stuck there.
I was told though that flush valves provided a stronger flush than syphons - so wonder if that could be why the syphon does not work with the new pan? Any ideas on that? Dave
what is the make of the syphon you have now fitted? theoretically [cor that was hard work] it should be more than adequate as new pan bowls are designed to work with less wateri.e 6ltrs so your old cistern may have up to 9 ltrs to supply. I wonder if there is a problem with the water ways in the back inlet of your new pan perhaps an obstruction of some sort will look out for your reply:)regards turnpin
I've had a look at the receipt but it doesn't say what make the syphon is - I shall try and find out. Will also check to see if the flushcone is causing any problems and that everything else looks ok. Thanks again Turnpin.
Reply to Problem with concealed cistern flushing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a wall hung pan with a concealed cistern. The flush is the "old style" Grohe Eau2 dual flush pneumatic button. When pressed the flush valve...
1K
Hello, I'm seeking advice on resolving the persistent blockage issues with my downstairs toilet. A year ago, I replaced an 80s close-coupled...
I have a Geberit concealed cistern . This has a dual pneumatic flush, and has worked without any problems for a few years now. The short flush...
1K
i have 3 sottini toilets with a compact cistern. It has an ideal standard dual flush mechanism. 2" entry The ideal standard is poor quality in...
1K
Hi all Relatively inexperienced homeowner here. Apologies in advance if I get any terminology wrong. Today I noticed some limescale accumulation...
1K
