Discuss Shower tray next to window. Enclosure options? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
armyash
Subscribed
Hi everyone
Started a job today, bath out and put in tray.
I've advised against it but cust adamant. The tray is going in the corner but there is no where to fix an enclosure along one side because there is a window there.
I explained all this to them, even if I was to put an enclosure in water would still go behind the rail during use and run to the floor.
The only option at the minute is curtain across the window and an angled rail going around the tray with a curtain.
It will look as bad as it sounds.
No option of putting in smaller window.
Is there anything designed for situations like this?
Now this may be a big Nono to the clients tasts
Could you block off the right hand pain of the window like in the bottom section of the window pic ?
Now make a frame the size/ width of the screen set (e.g. Boxing the required amount you need plus 2")
And then multi panel or wall board (what ever there called over the top and the return to the window
If you understand??
Don't know what do you think
If you understand??
Thanks, this is along the lines of what I have spoken to them about just so there is somewhere to fix the enclosure. It's not going to look pretty, but will give them what they want.
Interesting as I'm in a similar boat and my local friendly plumbers' merchants don't really know, as usual.
Do enclosure manufacturers not make kits to allow the glass screen to go on three sides of the tray? There must be a market for this sort of thing!
Very limited one to be honest, if there was a commercially viable market they would do them already. I can count on 2 fingers where this has been an issue in 9 years of fitting bathrooms. I got round it with glass blocks like someone else has said.
Other plumbers merchants have suggested I can use a sliding door on a rectangular tray and two side panels. Will work, if you're not committed to a quadrant and don't mind a slight gap between the window and the shower tray panel (and that's what I'm going to base my quote on).
True, but customer is 90, in sheltered housing, and this is his only bathroom. He said if if he ever gets really disabled, he'd want to move to a care home anyway. Customer can't see well and already has tiles that don't match and really doesn't care that much. He's already had quotes saying he must change his dangerous (?!) mixer shower (balanced pressures, unvented cylinder, so what's wrong with it?) for an electric one, and I think he wants what he wants.
Do I really tell him I have to put glass blocks over two feet of his window and he has to wait a few extra days without a working shower while I remove the existing tiled sill and then lay blocks and wait while mortar (and grout?) sets? Also, I would then have to screw into those glass blocks as the window finishes higher than the enclosure will - is this even possible? Or do I just say there will be a gap between the enclosure and window and he (or his cleaner) will have to use a feather duster or similar (which is exactly the status quo which he's happy with).
Can you see where I'm coming from?
Reply to Shower tray next to window. Enclosure options? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've got an issue with the shower tray not being totally flat. As you can see from the photos, it is about 7mm out at one side. It's leaning towards the waste end though. The shower tray is pushed underneath the tiles. My mate did the tiling and I now realise that we should have put the shower...
Hi all Plumber who fitted shower frame didnt put sealent behind frame to tray before fitting frame. Now leaks when water gets into frame and down into downstairs wall Another plumber has sealed inside area whwre it is shown yellow , which i get is not ideal. i was going to just seal a thin...
Hi all, I've got a new customer who wants a bathroom fitting. This would include a shower tray, and shower panel being situated partly across a window. It's far from ideal, but they've already bought the shower tray/panel/etc. It's a tiny bathroom, with no options for changing the layout...
Hi all. Shower is leaking into downstairs when water is being aimed at wall . All sealant has been redone on outside and between shower tray and wall at the bottom on inside , can’t spot any leakages here. It runs down the wall downstairs beneath shower in lines , when water is sprayed at the...
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old fittings, and old wall tiles and floor carpet). This consisted of a quadrant shower enclosure, a stone-resin shower tray, new ceramic tiles on the floor and half tiling on the walls. All the work...
