Discuss servicing related woes..... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Do you have any voltage going to the gas valve? If you do put your manometer on the inlet shut the gas and fire it up. if it drops the gas valve is opening if it doesn't its not.
What you might of done is adjust the maximum and knocked the minimum down too low so it wont fire up.
thanks for the input guys, new valve will be here tomorrow so will try above mentioned then.
shaun, i take it you mean remove gas valve but leave wires connected so it operates then blast air through bottom of valve and see if it opens up.
to be fair that might be right as i did have to adjust the valve a little to get correct burner readings, again i will check out tomorrow. thanks
It's so helpful to be able to come on here and get friendly advice, we all have to start somewhere when starting to take on repairs and its nice to have folks that are helpful and willing.
most likly to be the low setting they all seem to drop down over time its the first thing to look at when you get intermittent firing
Been there the old glowworm ultimate you had to pivot pcb on hinge serviced loads on a site 2 needed pcbs after due to dry joints.
youre doing this to make money this how you pay your rent.
if you put in a new gas valve for free will you ever make that money back from this customer. next time boiler needs work is she going to call you, if the answers 'no' she has to pay for the new gas valve otherwise youre paying her to fix her boiler
Reply to servicing related woes..... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My daughter lives alone in a 3 bed semi in the west country. The house is 20 years old. The central heating and hot water are provided from a...
Just been to a nightmare of a job! Had to carry out a service on the 2009 British Gas 330 + (GC: 41-019-11) It's a Glow Worm boiler. The boiler...
H
I need some help and advice with a boiler issue. We have F29 and then F29 appearing on our new boiler. This happened after few days where water...
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise...
British Gas servicing the above boiler ramped up the boiler to maximum in the installer menu to do flue gas analysis. They also measured the...
