Discuss servicing a gas fire in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Jennie
Hi all,
I've got a theoretical question about servicing gas fires.
When you take the gas fire out of the chimney (to do the smoke test, etc), do you routinely dismantle the pilot/burner pipes and injector and clean them as well? By blowing compressed air through the dismantled pipes?
The gas engineer I was apprenticed to never did. But I know others do.
It strikes me that if the flame picture is good, and the burner pressures correct, repeatedly opening up the joints every year may not be warranted.
Meanwhile, I always dust down the coals with a soft brush, and also brush down/hoover the recess and the burner tray, etc.
I'd be interested to hear your thoughts.
Thanks in advance,
Jennie
Yes. I'm a relative newbie - I've only been qualified for a year, so have a lot to learn on the finer points of putting it into practise.
Jennie, can you please send an image of your gsr card to [email protected].
You'll get access to the private forum.
When you have your yellow badge up I'll happily move and reopen this thread for you.
Reply to servicing a gas fire in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down through slab and out through deadwork into a manhole. I will work out falls from manhole and set the height of the waste water system as required. For...
