Discuss Sample Gas ACS questions in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Bit of a out burst there
Do you feel better now you have got that off your chest heatman
Hi lads.
I have to ask, but do you have permission to post those questions on the forum. Are they protected by copyright??
We had a problem on the sparks forum with course notes and past papers which we had to remove.
Cheers
Thanks Heatman.:)
Oven thermostat which goes out at by-pass rate
A oven thermostat by-pass may become blocked, causing the flame to go out when the oven reaches temprature and the flame size reduces down , for example gas flow is interrupted through the bypass
the answer here is to clean the by-pass orifice screw. reassemble and check the cooker operation. when cleaning be careful not to enlarge the orifice to the bypass.
understand now the question is perhaps not worded well
i get it the thermostat drops the flame when it reaches a set temp but keeps it allight via the bypass
as opposed to doing a manual test when oven is hot of turning flame down to see if it stays allight on low
whereas if flame supervision was faulty gas wld still stay on low i suppose via the bypass
couldnt blve that the gas still gets in even if the gas valve shuts via a bypass when i asked my instructor didnt seem to make sense that gas still flows if a flame goes out??
Reply to Sample Gas ACS questions in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
  • Locked
Hi, Im still on a learning curve here and would appreciate a little info on servicing procedure / landlords safety check for Gas hobs / cookers...
19K
  • Locked
Hi , Here are my question and would appreciate some help and advice. I am new to the buisness and am a little green . 1 How do you check...
2K
REDSAW
R
  • Locked
Situation: I own a lovely sleek contemporary NEFF GAS hob its about 3 years old. And of course during the use of this appliance we will put a...
8K
365drills
A
  • Locked
Anyone looking to become a plumber should aim for these Firstly (4 Years Day Release or Fast Track Company in about 24 weeks in total): - 6129...
14K
