Discuss Roca Duo in wall cistern how to remove plate? in the USA area at PlumbersForums.net
Hi Guys (and Gals)....
Just moved into a new house, all fine, except today the main bathroom cistern started overflowing (into the pan).
I think its a Roca Duo, with the L1 plate (from the Roca website).
I've watched a couple of youtube vids on how to check these etc, but I've failed at the first hurdle as I can't get the face plate off to get access to the inner gubbings!
How do I remove the face plate?
The vids show the bottom of the plate being pulled out, and mine does click a bit when I pull the bottom out, but it will not come off and I'm reluctant to force it?
See attached pics of the offending article.
Once the plate is off i'll have a quick gander at the innards and see whats what....
Cheers
Think you have to slide the whole lot up a bit and then put from the wall
Hi, thanx , I assume you mean slide it up then PULL from the wall?
will give it a try, but I was reluctant to just wrench it off the wall, as the couple of vids I've seen show it coming off quite easily. :cool:
Yes should come off easy
Ok, update, my plate had to be pressed sideways (to the RHS) to release it, not up, which took me ages to figure that out!
So I got the plate off ok. But.... I cannot seem to get the "inner" box out? all the you tube clips show the inner box being removed, which then gives more access to get the valve or flush mechanism out, but mine does not seem to budge? (See pic)
And, again, this being new to me, I don't want to force it or break it?
The youtube vids show the plastic lugs being turned to release the inner box, but mine don't seem to want to turn at all?
Anyway, I managed to get my hand inside enough and twist the threaded float valve to adjust it and lower it a bit, so it now shuts off earlier, so does not overflow any more, but I would still like to get the valve assembly out and give it a clean, service, etc. I know the "torbeck" type washers are known to fail, so I bought a spare just in case.
Is there a "knack" to getting the inner box out?
Cheers...
You might not be able to remove the box sometimes it’s screwed externally
You should be able to repair anything from inside with the box / shroud on
Reply to Roca Duo in wall cistern how to remove plate? in the USA area at PlumbersForums.net
I'm trying to pull a Polypipe SA62B access plug and cap out of the soil vent branch (which I think is a Floplast SP190). It's a bit of a cramped...
2K
Hi all I've got an inbuilt pneaumatic push button cistern (came with the house) and the full flush is not working. The half flush works but isn't...
24K
This maybe isn't so much about asking for advice as giving it 🤔 I had a leaking HW cylinder (23 years old) that I got fed up patching up with...
2K
OK so disclaimer – i'm a millennial who hates DIY – BUT I sincerely want to learn and acknowledge I need to get over the embarrassment of not...
2K
G
  • Locked
Hi guys Hope someone can help a novice out! I just want to remove a rad so that I can have the wall behind re-skimmed. The LSV looks rather old...
2K
gomez
G
