E
eddiebrown424
round the exes who complained that her DHW was not working. Greenstar system boiler pressurised system was low pressure so I topped it up. There are 2 dials on the boiler one central heating and one for DHW. Read that the dhw dial only works if there is a diverter valve in the boiler but as there is a three port and two zone valves near the pressurised cylinder I assumed that there wasn't so only the central heating knob would work. The boiler fires fine with this on any setting bar frost stat. there are two danfoss stats and a controller by the boiler but no option for hot water only. I figured if the states were off or less than 10 degrees upstairs and down that the main diverter valve would work however it doesn't. There are TRVs but surely on such an expensive and complicated pressurised system with zone valves there must be a way of having hot water only other than turning off all the TRVs.
Any advice please
eddie
Any advice please
eddie
