Discuss Reverse Osmosis System- Which Tap? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, I am considering installing an Undersink RO System, space should not be an issue (I think).
We currently have a Quooker (instant boiling water) cylinder and tap installed which we hardly use.
I am planning to disconnect and remove the quooker tank from under the sink but the question is will I be able to continue to use the quooker special tap (it has a little red LED on its base) together with RO system, would this be compatible?
(This is mainly to do with making the RO install easier as the access to this tap looks tricky after initial inspection).
One more thing, as I understand it a booster pump is not normally needed with RO systems but some include a pump for extra cost.
Is there a benefit for having a pump?? (I'd say the water pressure in the house is standard).
Thanks in advance!
Ben.
Reply to Reverse Osmosis System- Which Tap? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
