Discuss Replacing P trap under kitchen sink in the DIY Plumbing Forum area at PlumbersForums.net
Hi there,
My under kitchen sink p trap is slightly leaking, I've tightened the nut and still a leak there. Looking to buy a replacement and the code on the pipe just now is McAlpine EN 274 3. Anyone know where I would get a replacement and I've seen various sizes? Thanks 😊
Picture of your existing set up would be useful can then properly advise
Thats it. You can see the leak just there. Not sure if only needs a washer or whole new replacement. Cheers
Take apart make sure everything clean few wraps of ptfe round 0 ring/ washer maybe very thin smear of silicone sealant re tighten.
If that fails new trap have a look on screwfix large selection.
Looks like it’s dropped undo the leaky nut and lift the nut and blue washer up then lift the trap up until it stops around 2-2.5” should be into the trap then slide the nut and blue washer down and tighten shouldn’t leak
That's a good pic, EG 93!
When you look at it, you'll notice that the 'outlet' pipe on the right is slightly above - or nigh-on level - with that leaking joint. That means that the whole 'U' part is always full of water, so if the O-ring there isn't perfect, it will seep.
Best first step is to place a tray under there to catch the waste water, and then undo both of these hand-tight connectors. If you're a complete newbie, then the one on the left undoes anti-clockwise as you look down on it, and the RH one undoes clockwise when ditto.
Undo both of these and you'll have a U-bend in your hand. Examine the O-rings on each end, and see what the issue is. Photos and come back on here if uncertain :)
Thanks guys, it seems as if as above said it has dropped! I moved it back and and tightened for now and no leak but the blue washer has snapped and needing replaced so I've ordered and new one to do so. Thanks again!
Reply to Replacing P trap under kitchen sink in the DIY Plumbing Forum area at PlumbersForums.net
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
Morning, Moved house a few months ago and first issue is having a slight leak on tap in kitchen. Went under sink to turn off water and there are...
Deleted member 120897
A while ago I replaced a leaky, corroded sink trap. That all appears to be fine, I can't find any leaks with it, and everything under the sink...
    • Winner
Hi all, I joined today and am a newbie at plumbing DIY. Thought I'd share my experience replacing the stopcock under my sink. The old one looked...
A
Hi, I am replacing a leaking push fit flexi tap connector under the bath with a compression fitting flexi. The problem is that the old pipe seems...
