Discuss Replacement pull-out shower hose in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
Ed_r
Hi I bought a replacement shower hose for a pull out shower.
It has a male connector end which attaches to the water supply. But the new one appears to be 1/2 inch when the original appears to be 5/8 inch in diameter.
The websites do not seem to specify which suggests a standard size which I dont have. Is it better to get a connector (if so where?) or should I buy a new hose at the right size, (if so where?)
I would be grateful for anyone steering me in right direction/
Are you saying the original one is bigger than the replacement? If anything I would have expected it might be 3/8" but can't help with 5/8" sorry.
Hmmm that's an interesting one! Hopefully someone will be able to help you :) Good luck
Reply to Replacement pull-out shower hose in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
