Discuss replace gas pipe ?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
royston
Just a what if situation ive been thinking about. What if you went to a job to up size a boiler pipe. There was a cooker installed and a gas fire on different feeds. Now when you did a drop there was a leak within the permissible tolerances. So if you then upgraded the gas supply to the boiler and found that the drop was exactly the same as before, meaning the leak was not on your new pipe and on existing feeds with fire and cooker connected, what would your outcome be ?. Think i would investigate, trace and repair, or cap offending appliance.
You could if you wished but so long as it is within limits and no worse than it was before with appliances connected there is no requirement to do so unless there is a smell of gas.
best plan would be to discuss options with the customer, and hopefully they would agree that the "best" option would be to repair the leak, if not you mark on your paperwork "Tightness test PASS*" then mark down "*2mb found, no smell of gas, customer advised" then you are covered and they have taken an informed decision to leave the drop
well 1st thing i do when i get there is test the gas.. even if the leaks in the limits id still do my best to find it. This is because if you do the job and something happens later on and your the last one on site ppl will blame you even if its not your fault. i find most ppl want no leaks in there house.
I had something similar to this few months ago , checked gas before any works and had a slight drop but no smell of gas . Renewed boiler new gas supply etc completed job and same drop but no smell of gas .Had a search around cooker and fire sprayed few joints etc and customer asked what i was doing so said tiny drop on gas just seeing if i could find it .Instant panic alert by customer over what was about a 1 mb drop over test period. Never found the drop had a sniffer out the all the usuals and no joy . Had several phone calls over the next few weeks over this customer panicing over what he was saying was a full blown leak , he had gas board out and they found nothing . In the end i phoned gas safe as customer was starting to do my head in and gas safe advised to re-new all the pipework to appliances and retest .
The moment you tell someone there is a gas leak they panic, use your judgement and follow the gas regs. If its less than the permissable drop and no smell of gas, there is no need to investigate it.
Phone gas safe and tell them that because they advise otherwise .
Reply to replace gas pipe ?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I’m having a gas cooker pipe capped off. The GS registered plumber/ fitter, has told me that to do this, he’ll also have to service the combi...
Recently noticed a gas smell coming from my ideal classic RS50 boiler. Cadent have been out and confirmed a small leak and capped off the gas. The...
Hi, Non-professional / knowledgeable person here. I'm a Brit in Romania who volunteers for a charity building an old peoples home for needy old...
About 10 months I started having issues with a gas like smell in my home and the gas board was unable to find any gas leak I've still got the...
Am I the only one struggling to find appliances' manuals online? I know it's hard enough with cookers and old gas fires but I've just been unable...
