Discuss Repairing a dripping tap - what’s next? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
You got it, the next thing is to unscrew the slim brass retaining nut.
Tool in ease of use/least likely to damage anything: a socket on a ratchet handle, a spanner of correct size, an adjustable spanner, a pair of stilsons, a pair of adjustable grips (water pump pliers).
If you don’t have any of the above; buy or borrow.
If you don’t want to, there is a nasty/dirty way of doing it - but potentially damage may occur… you can cut a shallow notch into the top surface of the retaining nut and insert an old flat bladed screwdriver at a slight angle. Then use a hammer to knock the end of the screwdriver so as to unwind the nut. (It is best to get someone else to hold the tap steady for this method - but really it’s a last resort as it can easily damage the nut - or slip and damage the chrome)
Go buy yourself a nice adjustable spanner - it’ll come in handy in future.
Thanks for the tip. I'll get one tomorrow. And I'll squirt a load of WD40 on it before I set off.
I bought an adjustable spanner but the nut absolutely refuses to move. In fact it’s become a bit oval and the spanner just slips round and is flattening the thread.
Any further ideas before I give up and call a plumber?
Ok so an electrician who was installing some lights for us also does taps and he managed to get the cartridge out. It required a better clamp and a certain level of “f it” when applying the right amount of force.
Next up is finding the correct cartridge. Searching for the product code N35HBS does not return anything in the UK.
Can anyone point me in the right direction please?
Don’t have a clue I’m guessing the steel rod is an indent eg click open
It’s one of them might be easier to change the tap
The only tap cartridge that resembles yours is this one. N35HBS - http://www.geargroup.cn/ProDetail.aspx?id1=4&id2=7&id3=92
It's from China where your tap was made.
Looking at the damage to those threads on the tap, maybe a new monobloc with a hot and cold separate cartridges might be an idea.
That is my thinking as well. Thank you very much for confirming this. And it has made my mind up that I’m going to have both taps replaced.
Thank you everybody for your advice.
Any time we come across one of these taps dripping, we replace the tap, its not worth all the messing about to try and get the cartridge out and then source a replacement. You can usually pick taps up for £50 out of Screwfix and the repair can be made that day
Reply to Repairing a dripping tap - what’s next? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
We had the bathrooms replaced when we moved in 2 years ago. This involved 2x bathrooms and 1x WC. Within the first few weeks, we noticed leaking...
Hello, I am a complete novice but am trying to repair a dripping tap using online instructons on replacing the valve. My kitchen mixer tap is...
2K
Hello All, One of my mixer taps is dripping. Quick research tells me to replace the washer. So I prise off the top of the tap, remove a screw...
2K
Deleted member 120897
Hello there, as a trainee plumber I have a couple of questions running through my head. Being a plumber if i was to go to fix a customers...
Hi there! our Heritage bath taps (see attached image) have a leak from the shower lever when diverted to the shower head. Unfortunately this...
4K
