Discuss Removing Old Toilet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Crystal Snow
Hi
Im just in the process of refitting a bathroom and wanted some advice on removing the toilet as it is quite an old toilet by the looks of things and im not sure what is the best way to tackle the removal of this toilet without causing any damage to the underground pipe.
The collar I assume needs to be chipped away using a chisel and mallet so its flush with the floor and then use a multikwik/swan neck attachment to fit to the new toilet which will have a horizontal waste pipe - I assume there will be a gap behind the cistern where i would have to build a shelf or something.
The other problem is the toilet does not seem to have any bolts which attach it to the ground?? i dug into the holes on the side of the toilet (As seen in pic) using a screwdriver but all im pulling up is rubble/dust.
I have attached a picture which shows the problem
Any advice is very much appreciated...
thanks
Hammer time! :hammer::hammer::hammer::hammer::hammer::hammer:
:welcome2:
The toilet pan is probably cemented in place so you will no doubt have to break it to get it out and then chip all the cement off the floor. Instead of smashing the collar of the soil pipe, try to chisel out the cement around the pipe and remove the pan first so you can see what the situation is.
thanks for the replies,
after chipping the cement off around the pipe is it just a case of fitting a new 90deg pipe inside the collar and then patching that up or is it best to take it down to floor level ?
Yes smash the old one and a suitable pan connection should be available.. oops.. bit too late. That loo looks like it is worth a few quid..!
:welcome2:
thanks for that, if i was able to pull out the existing pipe do i just get a part which fits inside the collar and then insert it all down and patch up?
put some screwed up newspaper or an old towel down the soil to catch any broken pottery etc that goes down so that it doesn't get blocked.
I love UKPF..
Honestly must apologise Raw85 lollz but it was a very fast explicit concisely briefed..! Brilliantly funny
Sorry it's taken so long to reply, busy weekend. Yes break out the existing pipe and fit a new pan connector. Personally I would use plumbers mait to seal the pipe in the collar as it's flexible and easy to remove if you want to change the toilet in the future.
Reply to Removing Old Toilet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down through slab and out through deadwork into a manhole. I will work out falls from manhole and set the height of the waste water system as required. For...
Boiler is SIRIUS THREE FS 70 Potterton commercial. Situation: We are small building contractors and my labourers managed to damage the radiator pipes during the strip out. Not the end of the world as damages happens. I am responsible builder and paying my bills and to repair the damages if...
