Discuss Remeha boilers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
REDSAW
i have to attend a breakdown tomorrow for this boiler and the fault reported is Eo!
anyone point me in the direction maybe by any chance of what the fault is ?
not worked on these before so what they like to repair?:ack2:
ta
what boiler but eo is normally something to do with flow or return sensors but check there is flow first
ta
Worked on a few every time i phoned up tech help (baxi) got through to same bloke called Henry.Parts were silly expensive tho one cust decided on new boiler due to cost of parts.
Same, I look after 2 Remeha's Quinta's about 12 years old and piped up in series, they are a pain. Every year after completing the CP12 they develop a fault. Same guy picks up and just says change the boards...£1200 quid each or could be the optimiser £1400! New boilers going in before Christmas
If it's a remeha quinta pro. The breakdown symbol I think your on about is EO 1. This normally signals that the PSU is faulty. It's a tiny memory card that sits in the right hand corner of the front panel when you lift the front cover off and lower the panel down. It's beside the main board behind the front display.
It's black and green in colour and not much bigger than the top half of your thumb.
Have had a few of these over the years
I think eo code is Remeha speak for rip me out and replace me with a decent boiler.
As you can tell I am not a fan of the domestic Remehas.
Reply to Remeha boilers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hiya - posting in this forum as I'm guessing this relates to my neighbour above's boiler, but I may be wrong so please say if so. Basically the attached pix and vids show my issue. I've got a small copper-looking pipe protruding from the wall above my rear tenement bedroom. It's dripping almost...
Hi All Bit of an urgent one being that time of year and can't get a plumber out until after xmas even on an emergency callout I have just tried to turn on my CH for the first time this year as I have a number of guests coming for xmas dinner but even after an hour all the rads are stone...
Oily smell from boiler recently before failed. Great plumber sorted though when opened external baffle at front of sealed flue the internal spring like tube lining outer insulation had all perished. Barn conversion with thick walls (763mm). Worcester Bosch say Flue Kits are obsolete and...
I have a 40 year old floor standing Glow Worm 45-60 boiler (open vent )which is in a cupboard in the centre of the house. Its an old workhouse and has been working without issue until now. The pilot light went out and now wont relight. It lights but as soon as you release the button it goes...
My heating system comprises an Ideal Logic 12 boiler located downstairs and a Gledhill OV SOL cylinder located upstairs . The problem is that when the Gledhill controls for the “hot water” and “central heading” are turned on the Ideal boiler makes a constant “clicking” noise and tries to start...
