Discuss Remeha Avanta 28C in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Chrissyan
I live in North East England in Redcar and for 5 years now I have had a Remeha Avanta, the only problem being to actually find a plumber to install it 5 years ago. The warranty ran out on the boiler this month so after 5 trouble free years, it has started playing up. The pressure keeps dropping to 0 and when it is topped up it either drops down again to 0 or climbs to 3 or higher & starts to leak. This has been going on now for over a week.
There does not seem to be a plumber in the area who is not too busy or is willing to help us with this. Most say they have no idea what a Remeha is and seem to think that getting parts will be difficult!
We believe it may be an expansion pack that is needed and perhaps seals too.
My questions are:
1. How likely is the problem to be the expansion pack?
2. To save time, is there any reason why we cannot order the expansion pack & seals on line ourselves (we have already sourced them) and worry about a plumber later
3. How can we find a plumber in the Redcar area that will come & deal with this within the next week?
Please, please can some kind person give me some advice? :yes:
I would not keep topping the boiler up with water as a leak inside could damage other electrical components.
I don't know why your struggling to get someone out to it, most plumbers would definitely have heard of a remeha (although not necessarily for good)
I would personally get the plumber to diagnose and source parts as then its on him if they are wrong
easy fix for a decent engineer realy just a service could cure it but may need a part as its been going over pressure
Thanks a lot everyone. I now have a (reluctant) plumber who has ordered the expansion pack & seals and is coming out on Wednesday to fit.
Alex if I didn't keep topping it up, I would have had no heat or hot water for a week now and the plumbers around here really do know this boiler at all!
Reply to Remeha Avanta 28C in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem...
Hello, I live in a two floor semi with a gravity fed conventional gas fired boiler (Potterton Kingfisher MF). The boiler is fed cold water from...
Hello. I am a homeowner and have a Valliant EcoTech 835 (2017). Serviced every year and worked like a treat until about a few months ago when I...
What the easiest way to find why my boiler is losing pressure. It is about 5 years old Vaillant combi boiler, we have just had 2 vertical radiator...
Oil boiler (now~15 years old) unvented system with 17 radiators. We moved in 5 years ago and I had to keep bleeding the same radiator. The bleed...
