Discuss Relatioinship between pipe diameter and socket depth in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
James O'Donnell
Hi just a quick one is ther a rough Relatioinship between pipe diameter and socket depth ie is the socket depth on 15mm copper a percentage of the diameter and if so does this run through the size range ie is the ratio the same for 22mm copper or 40mm waste.
Cheers for the info I just want to make it easier to measure and fit quicker.
why would you need to measure the socket depth? a quick look at a couple of fitings seems to sugest itsclose to one pipe diameter
Reply to Relatioinship between pipe diameter and socket depth in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Attached is a ground floor picture of the soil pipe in our home. There was originally a toilet which has now been permanently capped off and you...
1K
Hi all. Recently had a new combi installed (Glow-worm Energy 30kw) in a new location (moved from upstairs to down). The flow and returns now...
1K
A
Hi all - hoping to get some advice here on a plumbing issue in our house. When we are showering / filling the bath and another appliance draws...
Azonic
A
Hello, I'm installing a shower tray on a 4m run from the soil stack. Building control have specified 50mm pipe so that's what I've got. However...
2K
Hi So I am adding an en-suite to a downstairs bedroom and have to install a macerator. I will be using the SaniPlus Up. I was trying to get a...
3K
