Discuss Recommendations for new combi boiler install in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I'm looking for advice on replacing a back gas fired boiler with a new combi boiler. I was thinking of placing the new combi boiler in the store room where the mains gas meter is located. Been looking a Worcester Greenstar 32CDI compact combi boiler but really looking for recommendations on makes and models please. In the future I would like to do an extension out the back of the kitchen and was wondering if a water underfloor heating system would be a good idea for the kitchen, utility and conservatory. Could the underfloor heating be run off the combi boiler? Thanks for any advice or recommendations.
Use the search box and you will see dozens of threads like this. I am not a Worcester fan as are many of my colleagues on here. Overrated for what they are and the money they charge. What you need to do is get quotes. Get some engineers to properly survey it all for you and the new location. They will recommend boilers. You are welcome to get out take on here of the suggestions but I would nigh on guarantee that you ask 10 engineers you will likely get 7-8 different suggestions. In answer to your final question yes you can run underfloor from it
Thanks Riley. I'll be doing the work myself, such as piping and fitting new radiators, except for the gas works required. Learning as I go along and doing as much research as I can.
Only decent Worcester are the classic CDI’s, the new compacts aren’t very good in my opinion. You will find plenty of people who like Worcester but overall for the price, they aren’t value for money and there are better options out there.
As mentioned above gas safe have made it clear you can’t even hang a boiler unless qualified so this might get you in hot water. Better leaving it alone and consulting an engineer.
Thanks Scott. What make would you recommend?
Reply to Recommendations for new combi boiler install in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Locked
Hi, I recently fitted a new central heating circuit and ran hot and cold to the bathroom and kitchen in my property (I was a CORGI registered...
Hi. I recently had a renovation done. My builder installed a new Combi boiler instead of my system boiler. He connected the pipework to the...
Hi, I have a Worcester Bosch Greenstar 30Si combi boiler, the analog clock has stopped and the On-Timer-Off switch only works on Timer setting...
I have just had a boiler, hot water tank and power shower pump replaced on advice by my plumber. I have two separate boilers, heat/hotwater...
Hi All, Looking for a recommendation for a heat only boiler to replace my 30yrs old ideal boiler. Any makes you would recommend and any to avoid...
