Discuss Heat only new boiler recommendations? in the Central Heating Forum area at PlumbersForums.net
Hi All,
Looking for a recommendation for a heat only boiler to replace my 30yrs old ideal boiler.
Any makes you would recommend and any to avoid?
What’s your existing set up old rads or modern, copper cylinder etc ?
Modern radiator and cylinder that is pre insulated with the hard foam material
Cylinder by the boiler or away in the airing cupboard?
baxi 600 or 800 heat or viessmann 100 would be my choices you could go with an eph priority hot water kit as well
Reply to Heat only new boiler recommendations? in the Central Heating Forum area at PlumbersForums.net
