Discuss Really badly choked up boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Millsy 82
I went to an 18 month old Grant vortex combi 26 which was the worst i've ever seen to the point that the baffles had an inch of soot on top of them and when I pulled the swirl baffles out they were solid with soot. I cleaned it all out so it was sparkly clean changed nozzle etc etc
I was expecting he oil pump to be too high pressure but it was at 8 bar and the air setting was about 5.5 which I wouldnt of thought would be too far out. but it was smoking a treat so opened the air up until it was fairly clean then put my analyser in and I cant get the co2 below 12% with the oil pressure on 8 and I had to wind the air as far as I could.
In the end I dropped the oil presssure to 6.5 bar and I managed to get the co2 down to 11.4%. What I cant work out is why with the air fully open will it not drop below 12% is it because
A Its still burning off some muck around the heat exchanger. (this is my thought)
B They are not using Kerosene? and maybe using gas oil or even red diesel or something else?
Im going back early next week to check it again as it was so hoping it burns off all the muck and I can just reset it all back up and away it goes>
Hmm... What colour was the oil?
red diesel is gas oil btw :)
Did you change the nozzle?
also if its new, did you check the burner had the correct blast tube?
Should have dropped a smaller nozzle in for a week to help burn it off. I wouldn't want to stick my meter in that for a week. Have you checked the analyser filter?
wrong nozzle been fitted, or flue seal gone causing pocs to recirc, for 2 ideas
Yeah gave it a full service so new nozzle hose etc.
I didnt realise gas oil and red diesel were the same lol. It looked like kereosene to me
Did you check it was the right nozzle in the box? Flue is probably choked too, chuck a soot breaker in :/)
Checked the nozzle before I put it in to make sure it was what was written on the tub. Right nozzle for the boiler as I double checked the manual. I ran the boiler with the air hose disconnected as well no difference as I thought it may be something like that.
Did you replace the nozzle like for like or as per MI's?
i always get them up on my phone as i would say about a tenth of what i go too have the wrong nozzle!!
yup!
Analyser filter was clean I made sure it wasnt smoking before I put it in and the inside of the boiler was spotless by the time I finished on it. (Me on the other hand was covered from head to foot in soot!)
Do you reckon it could just be burning of the muck still then? Ive worked on loads of oil boilers over the last couple of years some badly choked up but none this bad and never came accross this problem.
Smells very different also. Were the FGA readings any better with the snorkel removed?
Reply to Really badly choked up boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Newbie here so feel free to teach me the etiquette of this place, and apologies for the lengthy opening post. The boiler started locking out...
About 12 days ago attended a boiler lock out. Apparently another plumber was there a week before to and adjusted the photo cell. .. It is a grant...
3K
Hi all, came across this forum this looking for information on my sooting up kitchen type indoor Enviromax. I'm a retired electronics/maintenance...
2K
I have an old but good Trianco EuroStar 50-60 (S) oil fired boiler with a Riello RBL G5 BF burner which has been well maintained and regularly...
8K
Hello All and thanks Lou i did write a reply but it would not let me send it? i am not sure what I am meant to write and I do not want to come...
