N
neil jolly
Hi i have just purchased a wood burner for use in my own house and all the tech i read says it can't be installed with a sealed hot water system, i understand a wood burner is an uncontrolled heat source, but i live in Spain & can't even buy an open vented cylinder! surely if i install a pipe thermostat to bring on heating pump at a given temperature + the normal pressure vessel, safety valve and heat leak radiator this would be safe? any advice appreciated, also the soon to be back up boiler is 20 meters away, i will install 28mm primary flow & return to the h/w tank creating a 60m loop, should this be adequate?
regards Neil.
regards Neil.
