Discuss Rayburn installation. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
neil jolly
Hi i have just purchased a wood burner for use in my own house and all the tech i read says it can't be installed with a sealed hot water system, i understand a wood burner is an uncontrolled heat source, but i live in Spain & can't even buy an open vented cylinder! surely if i install a pipe thermostat to bring on heating pump at a given temperature + the normal pressure vessel, safety valve and heat leak radiator this would be safe? any advice appreciated, also the soon to be back up boiler is 20 meters away, i will install 28mm primary flow & return to the h/w tank creating a 60m loop, should this be adequate?
regards Neil.
Welcome to the forum Neil, I'm not sure of the regs in Spain you may be best to call a local installer for help. Just be aware an unvented cylinder is a bomb if istalled incorrectly. It may be be possble with the correct safety equipement installed.
Welcome to the forums, Neil Jolly.
I'd say the idea is fine - BUT - what if there's a power cut or what happens if a rodent eats through the wire? It HAS to be open vented for safety reasons.
I'd second Ecowarm's thought and ask Jose in to have a look.
I guess same as previous replies. It is just as dangerous in Spain as it is in UK. The Rayburn itself, will need its own open vented circuit, fed with a feed & expansion tank, unless you install a thermal store instead of unvented unit. If unvented unit explodes, then could be " noche , noche! " :dead:
Reply to Rayburn installation. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Previously had a WB Greenstar R28 HE System boiler with 4 pipes and vented (gravity fed) cylinder. No valves or pumps outside of the boiler. Worked fine for 20 years. Decided to change to Viessmann 050-W System boiler when WB failed but keep the same set up with cylinder. Gas Safe installer I...
Deleted member 120897
I'm looking for help with an open vented central heating system that is pumping over. We have a thermal store that has two heat sources - gas central heating, and a wood burner - both feeds are pumped with a Wilo Smart A 25/4-130 circulation (one pump per feed). When the wood burner kicks in...
Hi, seeking some advice on a Rayburn and control of hot water. Leaving out a very long story, my mothers house is about 200 miles away from me and she has recently moved into a care home. My brother and I need to renovate this from afar in order to rent it out to help with funds for her...
7K
H
I have a Viessmann 100-w four pipe system boiler controlled by a Potterton EP2001. I have bought a Tado smart thermostat starter kit v3+ but can't find out how to wire it. I have seen mention of using a Tado extension kit but the Tado website says: Extension Kit The Extension Kit performs a...
1K
Interested on thoughts on this (I've also posted on another forum but thought this might be a better place to ask); Long time lurker, have gleamed some great knowledge from this site, finally signed up as I cant find an exact answer to the below. I'm not a heating engineer, but an electrical...
4K
