Discuss Radiator needs regular bleeding in the USA area at PlumbersForums.net
phj
One radiator in the house needs to be bled every week, it works fine otherwise and there is no sign of a leak near the radiator or in the pipes leading to it. Should I be worried about a leak?
Is it upstairs?
There is probably a leak elsewhere on the system and this radiator is where the air accumulates.
It wants sorting out, need to find where it is losing water.
Is the pressure relief valve on the boiler dripping outside for instance?
Yes it's the towel rail in the bathroom upstairs. There is a layer of dust on the pipes around the relief valve so no dripping there. I've looked at all the pipes I can see, but some are underneath floorboards and fitted carpets upstairs!
Ok. Is this a new problem or being going on for some time? Are you sure its air and not hydrogen when you vent the radiator? Hydrogen will have a rotten eggy smell.
Tie a plastic bag of water under the vent to see if its drawing in air, this sometimes only occurs when the circ pump starts or stops.
Reply to Radiator needs regular bleeding in the USA area at PlumbersForums.net
Oil boiler (now~15 years old) unvented system with 17 radiators. We moved in 5 years ago and I had to keep bleeding the same radiator. The bleed...
When I turn on our CH there's a lot of noise from one specific part of the system - the pipes on the landing, and one radiator. It sounds like...
I bought the a bleed valve from S****fix about a year ago: s****fix.com/p/radiator-vent-blanking-plug-nickel-2-pack/40972 It worked fine...
Hi, Sorry if question already answered in previous posts, but I can't find a solution to the below: We recently moved house to a new home that...
Would like some help please as my Drayton Wiser system is a mess. I had 2 TRVs in the lounge, one in the main bedroom, the rest of the house - 6...
