Discuss Radiant gas fire in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Are you gas safe registered?
If so, please read the forum rules about advice on gas appliances on an open forum.
If not. "Same as above"
Sorry I haven't wrote that specifically. I am a customer and British Gas have ID'd the appliance for signs of schorching on Capet below fire would you agree on this? Cheers
Kind regards
Yes it's id. Has the fire been seviced! And could a hearth be fitted?
Disagree. To the letter of law this should be classified AR as per GIUSP.
id but its down to engineers opinion at the time
Thanks for your reply. Since posting this correct me if I am wrong but this is section 7.10 from unsafe situations edition 7 (updated unsafe situations)?
Kind Regards
So this is classified as at risk as evidence heat near to combustibles? The fire is defiantly coming out and replacing with solid fuel log burner with liner I think haha
make sure who ever install it is hetas registered
All this regulation reading is well and good and is there for a reason.
However, speaking as an engineer and obviously in my own opinion:-
Every job must be taken on its own merits.
The decision between AR and ID is basically
whether something dangerous might possibly happen AR
or definitely will or has happened ID
On top of this black and white decision making comes the Engineers discretion.
He or she has to decide between the two.
Looking at the scorched carpet idea, if I was in that position and needed to make a decision on whether it was safe to leave it or not, my choice would be ID ! Mainly because your carpet has scorched it just hasn't reached an ignition temperature ........yet !
Then when I go home, I can sleep easy without worrying about house fires. I suspect the BG engineer did the same and most people I know would too. ( bare in mind we haven't seen this).
If you brought the people who wrote that AR description to the property and ask them to sign their name and take responsibility for it, my bet is they would also use discretion and arrive at the same conclusion as BG
The point I'm making is, that just because it says something in a rule book, that doesn't always outway an experienced engineers decision making and does not necessarily make their decision wrong.
The fires going anyway now but as above. Log burner is hotter still and needs a registered and qualified installer.
My reason for ID. would be that the carpet is scorched and below! The fire.that takes a lot of heat. If you have a little heat damage to a painted surround above the fire, in my Veiw, that would be AR.
Both are scorched, but completely differing scenarios.
You have to make a decision based on what may happen after you have gone.
Reply to Radiant gas fire in the Plumbing Jobs | The Job-board area at PlumbersForums.net
