Discuss Questions about installing a thermostat for traditional boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • I've a traditional, non combi boiler. (with a hot water tank)
  • I've an immersion heater.
  • I've no central heating thermostat.
  • I have a manual thermostat attached on the boiler which I suspect is the water temperature but i'm not sure
How much of a task is it to install a brand new smart thermostat (for the central heating)? Is it even possible?
(Disclaimer I am not a plumber, I am a customer who knows nothing about plumbing)
Do you have a programmer? (Timings for your hot water/heating)
Do you have zone valves/mid position valve?
A picture of your cyclinder cupboard may answer this if you're unsure.
If you have these it wouldn't be much of a task, a lot of wireless options available nowadays
Hi Bill, thanks for replying.
OK I took a look and i've the following:
1) Drayton HTS3 cylinder stat
2) Drayton LP241 programmer
3) this monstrosity. ( the green thing says Wilo gold 50 on it)
does this give you any idea if it's possible?
Wow great! So is the job to replace the programmer unit with a "smart" one, and job done?!
P.s. do I have a "mid position valve" as bill asked?
Edit: does this also mean I can finally have a "wireless thermostat" as opposed to no thermostat?
Yes mate you do have a y plan system.
Look at the twin channel hive thermostat
I think if I can get something which:
  • gave me the control to turn on or off from outside the home
  • gave me a thermostat
I'd save some money compared to today
You need the control within your home , the on / off away from home unless you work weird shifts not knowing when you will be home isnt needed IMO , if you have a well insulated home it is cheaper to turn the heating down (ie just take the chill off ) not turn it off .
I'm not sure I'm able to turn it down though,at least I don't know how to do it
Can I buy a smart programmer together with a thermostat?
Start again mate , are you fine with your programmer coming on at set times every day , i.e do you generally go to work , go out etc etc at the same times throughout your normal week , if you do , IMO you just need a room stat .
If you work stupid shifts , go out loads at different times , dont come home the odd night etc etc then go for a app type system , nest , hive , lyric etc etc.
Reply to Questions about installing a thermostat for traditional boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
