Discuss Problem with connector - tubes not linking together - help? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
CanonM
Hi there,
I'm trying to fix a bit of plastic piping that falling away from it's connector but can't seem to get it back it and it held firm in place, please can you help?
Please see picture here of the problem:
[DLMURL="http://www.flickr.com/photos/jtfisher/5372139019/"]DSCF2072 | Flickr - Photo Sharing![/DLMURL]
I've tried screwing it tight but it won't hold, just slips out - it leads to a drain so water from what I think is the sink in the upstairs kitchen is coming down through it.
Joe
is the rubber ring there that goes around the pipe behind the nut in the sequence on pipe, nut-plastic ring-rubber ring. the rubber ring forms the seal when the nut is tightened, forcing the plastic ring onto the rubber ring.
oh and welcome to the forums.
Hi Steve,
No, doesn't look like it - have taken off the nut and checked but can only see what looks like a thin clay coloured small ring... What do I do?
Joe
you need the rubber ring. easiest way is to buy another compression fitting of the same size for the pipe and just use one from that.
Thanks Steve, how easy is it to buy - local DIY store? Anything I need to say, provide (measurements etc?)
Joe
if you take off the fitting that is already there and ask for exactly the same they will be able to help either from the likes of b&poo or local hardware store.
look inside the fitting, bet it will be jammed up inside, use a thin blade screqdriver to get it out, and as advised put the nut on the pipe, then the thin plastic ring then the rubber cone washer, thin side facing into the fitting, when tightened it will be solid, could be doing with clipping the pipe to hold it in place, any plumbers merchants will sell the fitting, best buy is McAlpine multifit, which looks like what you have.
as for size, if it is from a wash hand basin it will/should be 32mm, if a kitchen sink bath or shower it will/should be 38mm
It was stuck up there!
Will fit it back together now...
Thanks chaps!!
Reply to Problem with connector - tubes not linking together - help? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
I have an Arteform shower valve in my bathroom - top lever for the main shower head, middle for the handheld hose and bottom is the thermostatic...
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
Hi there, First of all, apologies for the quality of the attached image - unfortunately the access to the underside of the boiler is quite tight...
L
I have a problem with my dishwasher and I’m told there’s an issue with my plumbing. I’m after some help with understanding what the issue is (and...
We are replacing our kitchen mixer tap, but I haven't figured out how to remove the old one yet as I'm a lowly DIY-er and unfamiliar with the...
2K
