Discuss problem with clock or boiler? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
michael c
Hi guys, I fitted a potterton heatmax for my parents last year with zoned heating seperating the bathroom from rest of the house. All of a sudden the bathroom heating won't turn off. The thermostat is not calling for heat and i have turned the boiler to dhw only but heating is still running. Boiler is within warranty so will probably call the heat team out but would rather make sure its the boiler 1st. I do suspect a boiler fault however it throws me that it is just the one zone. Any ideas greatly appreciated. thanks
Reply to problem with clock or boiler? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an older gas boiler HW heating system with a taco circulator pump for each zone that worked fine last season. When turning it on for the...
Hi I have a Vokera 15 vhe boiler and all has been running well for the last 6 months since moving in up until a few weeks a go. Boiler throws up...
1K
I have just had a boiler, hot water tank and power shower pump replaced on advice by my plumber. I have two separate boilers, heat/hotwater...
Hi all, I have a wallstar combi oil fired boiler. We got low on oil a couple of weeks ago but didn't run out. Since we've had our oil delivered...
I would like to add an additional radiator to our central heating system. We have an attached double garage converted to a man-cave and workshop...
