Discuss pressure reducing valve? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi - called out to a property yesterday. The guy was complaining the toilet cistern was noisy filling and the valve closed with a thump. I found by closing down the main stopcock it solved the problem, The stopcock is now just about one half turn open , there is still plenty flow at the taps and the cistern fills quietly , but wondering if should recommend fitting a pressure reducing valve. Never fitted one before
thanks
dave
Was there an electric shower fitted? If so turning down the stop-valve that much will affect the peformance. Was there not an isolating valve at the cistern? Sound like a problem at the ballvalve
Scotty I have to disagree with you, why would there be a problem with the ball valve? just sounds like v. high pressure.
Also shutting down isolator on cistern will cause excessive noise if it is high pressure, Pressure reducing valve way to go imo
If this problem is a new problem on an existing system. I would of thought it would of been the diaphragm
Maybe even fitted a 1212pt4 with flow restricters
Most cistern ball valves should be able to cope with high pressure water, If it makes a thudding noise when shutting-off i would be pretty sure that it would be a torbeck style inletvalve there fore i would change it to brass styled one ( if possible) as they shut off more gradually which would prevent the thudding.
Getting a lot of pressure problems here in the SW, due to water board relining pipes, shower / taps / ball valves ect not likeing it also combi - boilers so best to fit PRV to serve all of house.
You could also considder fitting a shock arrestor, especially if fitting a prv you'll need an expansion vessel :)
Diamond an expansion vessel is not required on a cold water main?
I thought it was required if you fit a pressure reducing valve! What takes up the expansion of the cold water in the pipework of the house when the heating comes on and heats it up?
Reply to pressure reducing valve? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi there, I’m hoping someone can help me with this problem please. I’ve searched for similar posts but not found anything helpful! My mum’s...
A
Hi all - hoping to get some advice here on a plumbing issue in our house. When we are showering / filling the bath and another appliance draws...
Azonic
A
Hi, all. I have a leak problem behind the washing machine. It's a pipe that is leaking directly into a drain. It used to drip but now is leaking a...
Pritesh Patel
