Discuss pressure reducing valve cartridge leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
sebastienj
Hi all,
I think the pressure reducing valve cartridge on my pressure reducing valve is leaking. The pipe size is 22mm.
Where can I find a replacement for it?
I am clue less about what pressure and type it is.
here is a picture
https://goo.gl/photos/3UeYrT7gdt3rmhgcA
Seb
It should say on the blue cap what pressure rate it is, all decent plumbers merchants stock them!
There's nothing written on the cap, maybe it is under the dirt / limescale. I will remove it and take to the shop on Saturday.
https://goo.gl/photos/rpecjZnjHqjXX8jC8
Also I just noticed there's a screw on the end of the cap, it also looks like you can rotate the blue cap in any directions. What is this adjusting? The water pressure? How do I know that I have the correct adjustment.
Seb
yea that will work just set it to about 3-3.5 bar you will be fine
The valve is set just after the tap from the main. From the valve the pipe goes into my flat. It is cold water.
The cylinder is set way later in system
Reply to pressure reducing valve cartridge leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, My Blanco Kitchen Tap Model Swift BM1420 is leaking. Please see attached photos for details of where water leaks from. What I've done so...
I'm building a steam punk clock and am using a thermometer pressure gauge as one of the parts. What I need to know is how can I plumb to the rod...
Paul Alone
Hi, all. I have a leak problem behind the washing machine. It's a pipe that is leaking directly into a drain. It used to drip but now is leaking a...
Pritesh Patel
I have a Vaillant eco plus 837, year installed 2008. It works well. We have one large zone for the house with 13 rads running off it. We also...
C
Hi all. I hope one of you may have the answer i am looking for. I have four solenoid valves connected to the main water supply and they break all...
Christos83
C
